unable to install prpc7.1.8 in windows 8
hi,
I am getting below error while installing prpc7.1.8 version in windows 8,please give a solution for this.
BUILD FAILED
C:\Users\Satyanarayana\Desktop\pegainstall\pegaGuiInstallerTemp0\build.xml:115: Directory C:\Program Files\pega\PRPCPersonalEdition creation was not successful for an unknown reason
Total time: 0 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:89)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
... 2 more
--- Nested Exception ---
thanks,
venkat
Venkat,
According to the Pega 7.1.8 Personal Edition Installation Guide (page 3, Prerequisites), you must install on Windows 7.
The full installation guide can be found on the PDN here: https://pdn.pega.com/documents/personal-edition-installation-guide-718
Kind regards
Bob Lloyd
PDN/Pega Academy Forum Support Team
