unable to install 7.1.8 in windows 8
hi,
I am getting below error while installing 7.1.8 version in windows 8,please give a solution for this.
BUILD FAILED
C:\Users\Satyanarayana\Desktop\pegainstall\pegaGuiInstallerTemp0\build.xml:115: Directory C:\Program Files\pega\PRPCPersonalEdition creation was not successful for an unknown reason
Total time: 0 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:89)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
... 2 more
--- Nested Exception ---
thanks,
venkat
