Still seeing PEGA0017 alerts
I am still seeing PEGA0017 alerts after adding the following dynamic system settings (in Pega-Engine):
prconfig/datapages/mrucapacity/default = 3000
prconfig/declaratives/fragments/instancecountlimit/default = 5000
All nodes were restarted after making these changes. The alert log entry is as follows:
...PEGA0017*1000*1000*...;*declaratives/declarepages: Successfully reduced Concurrent MRU Map by201 down to: 1000.*
The alert log shows the threshold is 1000 as if my changes never took effect. How do I overcome this?
Also, it would be helpful if all prconfig settings were documented so I could determine if I am adding the proper dynamic system setting for this issue. A search on PDN does not bring up any results for Pega 7. When can we expect to see an update on this?
