Server not coming up after completion of upgrade scripts
The server dis not come up after deploying the prweb. The error message from the catalina logs are below. Please note we are directly giving our DB credentials in the prbootstrap.properties file
Configuration:
- upgrade from Pega 6.2 SP1 to Pega 7.1.9
- Java 1.7, Tomcat 7.0 and Oracle 11g
Errors found:
May 05, 2016 9:10:47 AM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
19830421: Loading bootstrap properties from /prbootstrap.properties
May 05, 2016 9:10:47 AM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
19830421: Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
19830421: Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
19830421: Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
19830421: Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
19830421: Bootstrap datatables schema: null
19830421: Archive version [0]
19830421: Engine schema defined in allclasses: null
19830421: Engine classes schema: null
19830421: Assembled classes schema: null
19830421: prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
19830421: Using latest detected engine version:(EngineCodeSetVersion= 06-02-10). To specify a different version, use the setting com.pega.pegarules.bootstrap.codeset.version.Pega-EngineCode in prbootstrap.properties.
May 05, 2016 9:10:47 AM com.pega.pegarules.internal.bootstrap.PRMiniLoader
19830421: Will load phase 2 bootstrap from Pega-EngineCode:06-02-10
May 05, 2016 9:10:47 AM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
SEVERE: Problem during method invocation (contextInitialized)
java.lang.NoClassDefFoundError: com/pega/pegarules/internal/bootstrap/BaseLogger
at com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl.<clinit>(PRBootstrapImpl.java:184)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:685)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4779)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5273)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:895)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:871)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:615)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:962)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:536)
at org.apache.catalina.startup.HostConfig.check(HostConfig.java:1471)
at org.apache.tomcat.util.modeler.BaseModelMBean.invoke(BaseModelMBean.java:301)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(Unknown Source)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(Unknown Source)
at org.apache.catalina.manager.ManagerServlet.check(ManagerServlet.java:1436)
at org.apache.catalina.manager.ManagerServlet.deploy(ManagerServlet.java:856)
at org.apache.catalina.manager.ManagerServlet.doGet(ManagerServlet.java:353)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:225)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:581)
at org.apache.catalina.valves.RequestFilterValve.process(RequestFilterValve.java:305)
at org.apache.catalina.valves.RemoteAddrValve.invoke(RemoteAddrValve.java:83)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:999)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:565)
at org.apache.tomcat.util.net.AprEndpoint$SocketWithOptionsProcessor.run(AprEndpoint.java:1770)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.BaseLogger
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:388)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 51 more
