Ernst & Young GDS Consulting
Last activity: 10 Jan 2017 5:42 EST
Vertical Scroll bar is not coming after upgrading the application from 5.5v to Pega 7.2
We are upgrading an application from 5.5 to 7.2. In previous version the harness contains the panel set which is deprecated in pega 7.2 and so we have used screen layout instead of the panel set. But using of screen layout have some couple of issue though it is responsive. One of the major issue issue we have found is the vertical scroll not comning in some of the portal and hence the full part of the screen is not visible. Is there any hot fix avialble for this. The version is we are using is 7.2.
***Updated by Moderator: Vidyaranjan. Removed user added #helpme and Ask the Expert tags. Apologies for confusion, shouldn't have been an end-user option***
***Updated by moderator: Marissa to update categories, add #helpme***
