Covance
Last activity: 6 Apr 2016 9:00 EDT
Rule set is not visible when trying to save as the rule
PRPC 7.1.7
There is frame work rule set that doesn’t display when save as the data transform rule. I have checked below areas.
1. Particular class doesn’t have any rule set restriction.
2. Rule set has been included in frame work application stack.
3. There is unlocked version available in rule set.
I am struggling to reveal logic here. Please help if possible.
Thanks in advance
Areteans Technology
Did you try to change the class or ruleset of the rule belongs to in a save as operation ?
thanks,
Ashok
Covance
Thank you very much for replying.
Yes. When i change the class(I changed the pattern which means remove the tail part of class) it displays the rule set.
As i mentioned above there is no any restriction we have made in class or application.
Techmahindra
Hi any one help me
Try to save as the binary file and create new binary rule
In both cases i am not able to find ruleset and ruleset version...
what may be the reason
please share your observations after commenting the step in activity rule pzFilterAvailableRuleSetVersionsForRecord in private edit.
note: login and logout is required after commenting the step.
Techmahindra
Not able to saveas and create rule in @baseclass.
No ruleset versions are appering even though there are unlocked ruleset versions and application stack is also seems ok. but not able to save rule from @base class
Please help out
Techmahindra
Hi Sahu,
After commenting step from pzFilterAvailableRuleSetVersionsForRecord activity ruleset versions are appering :)
but how can i fix in my application
is the application upgraded from 6x series to Pega 7?
if yes... could you please refer to additional components folder in PRPC distribution folder to run additional SQL scripts.
otherwise please raise an SR.
Updated: 6 Apr 2016 9:00 EDT
Lloyds
Mattia Rosellini
