Last activity: 10 Dec 2021 15:49 EST
RPA Microsoft Word Automation -- Retrieving Document Statistics
The MicrosoftWord connector allows you to retrieve statistics from a document. Here is a sample automation that you can import into your projects to perform that task. To call this automation your input parameters include:
- a reference to your MicrosoftWord connector
- a Microsoft.Office.Interop.Word.WdSaveFormat value which identifies the statistic to retrieve
- a boolean that specifies whether the Foot notes and End notes should be included in the statistics
A couple of items for your attention:
- The WordConnector WordDocument property gives you access to all of the properties, methods and events of your document. Extract a proxy from that property and explore the wealth of options available.
- Many of the methods available in Word have a number of parameters that you may not need or want to provide. The MicrosoftExcel connector has a property called Missing which can be used to supply these parameters (we will add this to the MicrosoftWord connector soon).
- Many methods require special types of input but you cannot select the input directly on the block. Notice how we use an input parameter to select from a Word enum value and then use it in the method.
- To learn what enum value to use, refer to Microsoft's documentation found here- https://docs.microsoft.com/en-us/dotnet/api/microsoft.office.interop.word?view=word-pia. Find the name of the enum and then using the Browse option when adding a parameter navigate to Microsoft.Office.Interop.Word to find the enum by name.
Hope this help you get started doing complex automations in Microsoft Word.
Sneak peak of the same automation in Pega Robot Studio v21 (preview is now available on Digital Delivery).
