Update: Based on feedback from Pega and other users, Microsoft has released an update to Edge, version 113.0.1774.42, that reverts the change that affected Pega RPA’s ability to work with Edge version 113.0.1774.35. The Pega RPA team has tested this latest Microsoft update and found that it allows you to automate Edge just as before, with older versions of Pega Robotic Automation software.
If you install Edge version 113.0.1774.42, Pega RPA and Microsoft Edge will work as they did before you installed Edge version 113.0.1774.35.
Be advised, however, that this change and others, could be re-applied at a later date. As always, we encourage you to turn off automatic updates of your browsers; only pushing out new versions after you have had time to smoke test your automations.
The following table explains your options, but the bottom line is that if Microsoft Edge v113.0.1774.42 is installed, then the issue introduced with Microsoft Edge v113.0.1774.35 will not affect you, no matter what version of Pega RPA or Pega Browser Extension (PBE) is in use.
If you have Pega |
And you install |
| Version 22.1 (which includes PBE) |
Microsoft Edge v113.0.1774.42 |
| Version 19.1 and PBE |
Microsoft Edge v113.0.1774.42 Pega RPA should work as before. |
| Version 19.1 and the legacy browser extension |
| Any version |
Microsoft Edge v113.0.1774.35 - Install Microsoft Edge v113.0.1774.42. |
Note: The best practice is to move to Pega Browser Extension (PBE), if you have not done so already, at your earliest convenience. Doing so will help you avoid future problems and will also simplify the process of updating your software. For the latest information, see Pega Browser Extension FAQ.
If you need assistance in resolving this issue, please create a support ticket on the My Support Portal page. For more information, see Creating a support ticket.
On May 5th, 2023, Microsoft released an update to the Microsoft Edge browser (version 113.0.1774.35). We have detected an issue with this Microsoft update that causes problems when you automate Microsoft Edge using Pega Robotic Automation.
The Pega RPA team has created an update to Pega Robotic Automation that addresses this issue. If you are automating applications that run on Microsoft Edge, please go to the My Software portal and download the latest updates. Install the updates as you would any other update. For more information on downloading the update, see Downloading Pega Robotic Automation software.
| If you use | Install build |
| Pega Browser Extension (PBE) with v22.1 or v19.1 | PBE 3.1.13 or later |
| The legacy Edge browser extension with v19.1 | 19.1.125 or later |
Note: If you previously rolled back the Microsoft Edge 113 update, you can reinstall it after you update your Pega Robotic Automation software. We recommend that you turn off automatic updates for the Microsoft Edge browser. For instructions, see How to roll back Microsoft Edge to a previous version.
@MichaelNorton Hi, This has already started impacting automations with Edge. Could you let us know when / how a fix will be applied? Do we expect any new browser extension to be released to work with Edge 113? Do we expect any issues with Chrome as both are built on Chromium. We haven't seen any issues with automations using Chrome. Just want to make sure.
