Virtusapolaris
"PZUPGRADERULEMESSAGES - Rule not found exception"
While performing the Rules upgrade it failed due to some DB issues. We resolved the issues and resumed the operation using 'resume.sh' but again the Rules upgrade failed during "Upgrade Rule Messages" step with the following exception. Kindly help us in resolving the issue.
java] 2015-07-28 16:48:16,570 [ WGUPTS10W7HYD] [ STANDARD] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES engine successfully started. TimeZone: Asia/Calcutta AESPerfStatMode: PUSH Server: WGUPTS10W7HYD System: y55_test Description: WGUPTS10W7HYD y55_test 2015-07-28 06:58:22.584 GMT URL: [unable to determine]
[java] 2015-07-28 16:48:16,572 [ WGUPTS10W7HYD] [ STANDARD] [ ] ( internal.mgmt.EngineImpl) INFO - Embedded Environment initialization is complete.
[java] 2015-07-28 16:48:16,580 [ WGUPTS10W7HYD] [ STANDARD] [ ] (ernal.util.UpgradeRuleMessages) INFO - Upgrading Rule-Message instances...
[java] 2015-07-28 16:48:17,317 [ WGUPTS10W7HYD] [ STANDARD] [ ] (l.access.RuleCandidateIterator) INFO - Single candidate rule resolution optimization is enabled
[java] Jul 28, 2015 4:48:18 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.generator.RuleNotFoundException: pyVTable-RuleNotFound-NoMatches RULE-OBJ-ACTIVITY PZUPGRADERULEMESSAGES Pega-Landing-System-Upgrade 2 The 2 rules named 'PZUPGRADERULEMESSAGES' defined in the rulebase are:
[java] 2 related to applies-to class 'Pega-Landing-System-Upgrade', but were defined in rulesets which are not in your rulesetlist: {Pega-LP-SystemSettings:07-10-15, Pega-LP-SystemSettings:07-10-17}.
[java]
[java]
[java] Current RulesetList:
[java] Pega-ProcessCommander:06-02,
[java] Pega-LP-ProcessAndRules:06-02,
[java] Pega-LP-Integration:06-02,
[java] Pega-LP-Reports:06-02,
[java] Pega-LP-SystemSettings:06-02,
[java] Pega-LP-UserInterface:06-02,
[java] Pega-LP-OrgAndSecurity:06-02,
[java] Pega-LP-DataModel:06-02,
[java] Pega-LP-Application:06-02,
[java] Pega-LP:06-02,
[java] Pega-UpdateManager:06-02,
[java] Pega-SecurityVA:06-02,
[java] Pega-Feedback:06-02,
[java] Pega-AutoTest:06-02,
[java] Pega-AppDefinition:06-02,
[java] Pega-ImportExport:06-02,
[java] Pega-LocalizationTools:06-02,
[java] Pega-RuleRefactoring:06-02,
[java] Pega-ProcessArchitect:06-02,
[java] Pega-Portlet:06-02,
[java] Pega-Content:06-02,
[java] Pega-IntegrationArchitect:06-02,
[java] Pega-SystemArchitect:06-02,
[java] Pega-Desktop:06-02,
[java] Pega-EndUserUI:06-02,
[java] Pega-EventProcessing:06-02,
[java] Pega-Reporting:06-02,
[java] Pega-UIDesign:06-02,
[java] Pega-Gadgets:06-02,
[java] Pega-UIEngine:06-02,
[java] Pega-ProcessEngine:06-02,
[java] Pega-SearchEngine:06-02,
[java] Pega-IntegrationEngine:06-02,
[java] Pega-RulesEngine:06-02,
[java] Pega-Engine:06-02,
[java] Pega-ProCom:06-02,
[java] Pega-IntSvcs:06-02,
[java] Pega-WB:06-02,
[java] Pega-RULES:06-02
[java]
[java] at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.throwDetailedRuleNotFoundException(VirtualTableResolver.java:726)
[java] at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveToContainer(VirtualTableResolver.java:401)
[java] at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveRule(VirtualTableResolver.java:155)
[java] at com.pega.pegarules.generation.internal.vtable.VirtualTableImpl.resolveRule(VirtualTableImpl.java:301)
[java] at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:474)
[java] at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3483)
[java] at com.pega.pegarules.deploy.internal.util.UpgradeRuleMessages.main(UpgradeRuleMessages.java:79)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:601)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java]
[java] Exception in thread "WGUPTS10W7HYD" java.lang.RuntimeException: Problem during method invocation (main)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:278)
[java] Caused by: com.pega.pegarules.pub.generator.RuleNotFoundException: pyVTable-RuleNotFound-NoMatches RULE-OBJ-ACTIVITY PZUPGRADERULEMESSAGES Pega-Landing-System-Upgrade 2 The 2 rules named 'PZUPGRADERULEMESSAGES' defined in the rulebase are:
[java]
[java]
[java]
[java] ... 1 more
BUILD FAILED
C:\Pega7.1.8\scripts\setupDatabase.xml:317: The following error occurred while executing this line:
C:\Pega7.1.8\scripts\setupDatabase.xml:2333: Java returned: 1
