PRPC 61 to Pega 7.2 rule upgrade faile with unique constraint PR_INDEX_REFERENCE_PK violated error
As part of the upgrade from PRPC 6.x to Pega 7 rules upgrade is failed with the following error.
[java] 2016-05-23 15:09:52,671 [ main] [ ] [ ] ( internal.loaders.FastLoader) ERROR - Encountered batch element exception:
[java] java.sql.SQLIntegrityConstraintViolationException: ORA-00001: unique constraint (RULES.PR_INDEX_REFERENCE_PK) violated
[java]
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:447)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
[java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:951)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:513)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:227)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
The main reason for this issue is PegaUVU ruleset got refactored as Pega-UVU in Pega 7.1.8 included in the base product, in old release customers need to import this ruleset separately.
As Upgrade process is removing only Pega- references as shown below not removing any PegaUVU ruleset references, So when it is trying to import the index references it is failing with unique constraint error as both the PegaUVU and Pega-UVU has the same pzinskey.
As a work around you can remove the PegaUVU releated records in the PR_INDEX_REFERENCE table before you trigger the upgrade.
delete from pr_index_reference where pxreferencingrulesetname like'PegaUVU%'
