CS7.1.4.1 jar import fails : Error Violation of PRIMARY KEY constraint 'pr4_rule_PK' Can't insert duplicate key in pr4_rule
We upgraded PRPC from 6.3 SP1 to 7.2. The upgrade is successful.
Now, we are upgrading CPM from CPM : 06.03 to CS : 7.1.4.1.
We checked the pre-requisites and executed drop trigger script. The CustomerService_714.jar import proceeds for 2-3 phases till the point it asks whether aged updated should be imported. We de-select the checkbox and proceed. Import fails with error "Save Failed: Violation of PRIMARY KEY constraint 'pr4_rule_PK'. Cannot insert duplicate key in object 'rules7.pr4_rule'. DatabaseException caused by prior exception: java.sql.BatchUpdateException: Violation of PRIMARY KEY constraint 'pr4_rule_PK'. Cannot insert duplicate key in object 'rules7.pr4_rule'. | SQL Code: 2627 | SQL State: 23000"
OS : Windows Server 2008 R2 Enterprise
App : Tomcat 7.0.39
DB : sql server 2008
Please look into it and advise how to proceed further.
