Accenture Federal Services
Last activity: 4 Mar 2016 14:16 EST
Getting ORA-00001: unique constraint violated when running install.sh
I'm in the process of installing Pega 7.1.9 with Oracle WebLogic, and ran into this error while running install.sh:
java.sql.SQLIntegrityConstraintViolationException: ORA-00001: unique constraint (PEGA_RULES.PR4_RULE_PROPERTY_PK) violated
This message was followed by a multitude of errors like the following (differing only by the key):
ERROR - The update for instance of type Rule-Obj-Property with key RULE-OBJ-PROPERTY @BASECLASS PXALLCHANGELIST #20130918T234213.729 GMT was aborted.
I checked my schema against the SQL scripts I ran (following the Installation Guide), and everything appears to have been set up correctly. Does anyone know what might be causing this primary key violation during installation?
