TCS
Posted: March 28, 2016
Last activity: April 6, 2018
Post Upgrade - This action is not allowed as it is outside the current transaction
I upgraded one of the customer's application in 6.1SP2 to 7.2 and configured with WAS 8.5
Post upgrade, I launched with login on administrator and proceed to IMPORT wizard so as to import framework's (BiX) jar files.
After I choose the path of the JAR file and clicked submit. I see the error message - "This action is not allowed as it is outside the current transaction."
In logs, I see the message.
2016-03-24 14:55:44,783 [ WebContainer : 0] [TABTHREAD0] [ ] [ PegaRULES:07.10] ( mgmt.base.ThreadUITransaction) ERROR 10.225.69.67|wchodb2w7hyd.rpega.com [email protected] - ERROR: posted transaction id 'ddd61c5b191cded3a517c8b6466b54db' for frame 'pyWorkPage' DOES NOT match record '3dc7e76d8e164cc3d2436e25971173ac'.
It would have made sense if I had received this message on submit of any forms of Customer code but receiving in the OOTB IMPORT wizard puzzles me.
But, when I re-configured the same 7.2 application with Tomcat, the above problem is not faced. I double checked to make sure WAS configuration are as per the Install/Upgrade guides.
Guys, Any clue ?
