Cognizant India Pvt. Ltd
Last activity: 23 Jan 2018 6:18 EST
How to run a video in pega Application.
We can run mp4 files in any section in an Pega application.In order to achieve this you need to follow the below mentioned steps:
Step 1 : upload a mp4 file as a binary file in webwb directory and save it.
Step 2: Create a section in work class and in HTML tab of the section uncheck "Auto generated HTML", it will give you space to write customized HTML code.
Step 3 : Add the following HTML snippet on that space
<video id='Test231' width="500" height="400" controls>
<source src="<pega:reference name="pxThread.pxReqBaseURI" mode="normal" />/webwb/MyVideo.mp4" type="video/mp4">
Your browser does not support the video tag.
</video>
<script>
document.getElementById("Test231").play();
</script>
*Test231 is the section name where you wrote that HTML code.
*/webwb/MyVideo.mp4 is the Id of the binary file you Uploaded (replace the . with /)
now you can add this section wherever you want.
***Edited by Moderator Marissa to change post type to Discussion***
Hi Achintya,
Thank you for sharing the article on How to run a video in Pega Application in the community. It would benefit all the users looking for steps on achieving this.
Thanks!
