Run: Exception invoking method - Error in the application.
problems while exiting the process. Can anyone suggest what could have gone wrong?
@AshKSHow are you exiting runtime? Are you calling the TerminateRuntime method? If so, make sure you do so asynchronously (right-click the execution link to it and mark it as asynchronous and the line should become dotted).
@AshKS An exception by itself does not necessarily mean anything is wrong. Is there a specific symptom you are experiencing? With that context maybe that would determine if this is of any concern. You mentioned in your sentence that this was during the process of exiting the application. Do you mean during exiting Pega Robotics or exiting the specific application you are integrating?
@ThomasSasnett exiting of pega robotics. Concern is it runs in unattended mode, it doesnot exit (here exit means closing all target application and finally close itself). When pega robotics application supposed to start next time it doesn't start because pega robotics app is already running in the system(virtual machine).
