Rabobank
Last activity: 2 May 2016 3:06 EDT
Exercise - Create a Report to List Waiting Candidates - Cannot add Candidate first and lastname properties to report
Hi all,
Am working on the "Create a Report to List Waiting Candidates" exercise. It seems i cannot add the candidate first and last name properties to the report by dragging the fields (see screenshot).
Am logged in as manager, using internet explorer 11 on windows 10.
Did i miss something or maybe a browser limitation?
Thanks in advance!
Rulesware
SV
In order to drag and drop you need to hover the mouse in the vertical points in the left of the property name you will see the pointer changes into a a 4 arrows icon, then you will be able to drag and drop. The same as you do when adding properties to a layout.
You may also try with pyFullname property?
Hope you can resolve it.
Rulesware
SV
Let us know how it goes!
Updated: 10 Feb 2016 3:51 EST
Rabobank
Hi Bryan,
Thanks for your hint :). Have tried it, but didn't work so far. I can hover all i like but no arrow shape. I do get a hand icon and other properties drag fine. Just the page properties wont appear on the report...
Kind Regards,
Niels
Ai4Process
I guess you tried another browser so a workaround would be to manually add the columns in the report definition rule itself (From the Designer Studio)
Damien
Pega Academy Support Team
Public Safety Canada
I have the same problem. IE 11 on Windows 10. Also tried on Firefox with no luck.
I grab the column, it drags to the right side and I see an orange insert line. I drop when I see the green checkmark, just nothing gets added.
I've only been able to add the Create Operator Name.
I used the workaround above and added the properties in the report definition in Designer Studio. Though it was difficult there too as the usual typing of "." didn't produce a dropdown of properties, I had to type it in myself and hope it was correct. Must be a Windows 10 issue.
There also doesn't seem to be any data in the Interview Date column?
Accenture
I have the same problem and am also using Windows 10. I tried in both IE 11 and google chrome.
Ai4Process
the auto-completion may not work for unoptimised properties.
Damien
Rabobank
Even when the properties show, it seems impossible to drag them to the report. I finished the report by editing the report directly from the rule.
Kind regards,
Niels
