ATOS
RS
Last activity: 30 Apr 2015 12:56 EDT
Error in deleting a case type
Hello Seynabou,
Could you provide some more information on what you were trying to do. How did you try and delete the Case Type? Which version of PRPC are you using? Please provide a screenshot if possible.
Andrew Fontenelle
PDN Support Team
ATOS
RS
I use pega 7 and I work in the designer studio environment.I want to create a new case type but I get this error.I created an case called Contrôle de gestion but I have deleted this and if I try to create another case I have this error.
Hello Seynabou,
Can you tell me exactly in detail how you tried delete the case type? What tools or commands did you use? Did you try and create a case type with the same name?
Andrew Fontenelle
PDN Support Team
ATOS
RS
Hello Seynabou,
I still don't have enough information about your problem to suggest a solution. Does the error occur when you try to create a new Case Type? Could you provide a screenshot and detailed steps of what you are doing?
Andrew Fontenelle
PDN Support Team
There is no wizard to delete the application and related components. I will pass this issue on to appropriate team.
Andrew Fontenelle
PDN Support Team
Hello Seynabou,
In order to resolve the issue that you are experiencing a thorough review of all of the factors contributing to the issue is required. Please submit a Service Request (SR) so that one of our Customer Support technicians can work with you on this. You can do so by contacting Pegasystems Global Technical Support through My Support Portal.
Andrew Fontenelle
PDN Support Team
