Atos
SN
Last activity: 9 Mar 2017 15:40 EST
delete a case type in pega7
hi, everybody
I want to delete a case type in PEGA 7, can anyone help me???
Hello Aminata,
Why do you wish to delete the case type? Have any instances of the type been created? Is this in a production or development system?
Andrew Fontenelle
PDN Support Team
Atos
SN
hi Fonta
this in a development system,i don't need it now!!
To remove the case type do the following (1) Use the Refactoring Rules -> Delete a Class (From Designer Studio | System | Tools) to delete the class associated with the case type and (2) Refresh the case types listed in the Case Designer.
I would not do this in a production system or if any instances of the type had already been created. Also be very careful if the case type has any subcases.
Andrew Fontenelle
PDN Support Team
Rakesh Burbure
Atos
SN
thanks Andew!!!! it's done now!!!
Accenture
Can someone please explain the disadvantages of performing case type deletion in production system? I would like to understand the risks involved in doing this activity in production.
Mithun Naik
CBA India Services Pvt Ltd
Hi All, i have one case type name is " Candidate" but unfortunately i did Refresh case type in Case explore so can i get back it Case tab in that same name like " Candidate". Can you please help me.
Hi P.,
I'm not sure I understand your question. Please re-phrase your question.
Henry
Pega Academy
Coforge
Hello All,
For Pega 7.1.x versions above,we can find the option to delete the class under,
System-->Refactor-->Classes
Then,we can use "Delete the Class" wizard to proceed further.
Karthik
Luxoft
For your question for delete a class you need to go through the 1)designer studio
2)system>Tools>Refactor rules>Delet a class
If u click on this Delet a class it opens a wizard for u for delet a class in first step
You need to give the case name in the 2nd step, there u are able to delet the case, and must conform is there any Sub-cases are in the present class ok
Thank You,
Fusion Technology
Would it be possible to delete a class that was created in a previous version?
