STC
Last activity: 20 Feb 2026 19:04 EST
Customizing Max Record Count in Pega Report Definitions
In Pega Report Definitions, we usually control the number of records using Max Records in the Data Access tab.
However, when a value is hard-coded there, the report always executes with the same record limit, which restricts flexibility.
Problem
Max Records defined in the Report Definition is static
The report is always invoked with that count
Dynamic use cases (pagination, batch processing, email digests, APIs) become difficult
Recommended Approach: Dynamic Record Count via Activity
Instead of defining Max Records in the Report Definition, we can control it dynamically at runtime using an Activity and ReportParameters.
Step-by-Step Implementation
Step 1: Remove Static Max Records
Open the Report Definition
Clear the Max Records value in the Data Access tab
Step 2: Create an Activity
Create a reusable activity to invoke the Report Definition dynamically.
Step 3: Page-New
Step:
Page-New -
Page Name:
ReportParameters -
Class:
Embed-QueryInputs
Important: Make sure this page is also declared in the Pages & Classes tab.
Step 4: Property-Set
Set the required Report Definition properties dynamically.
Step Page: ReportParameters
Set the following properties:
Param.pyReportName = <Report Definition Name> Param.pyReportClass = <Applies-To Class> Param.pyPageName = <Output Page Name> Param.pyReportParamPageName = ReportParameters .pyMaxRecords = <Desired Record Count>
.pyMaxRecords controls how many records the report retrieves at runtime [It can be from DSS too ].
Step 5: Call Report Definition
Use Call → Report Definition
The report will now execute using the dynamic Max Records you provided
Key Benefits
Dynamic control over report execution
Cleaner and reusable design
Ideal for email digests, dashboards, integrations, and batch jobs
Aligns with Pega best practices
Reference (OOTB Example)
To understand how Pega uses this pattern internally, refer to the OOTB activity:
Activity Name: pzSendEmailDigest
This activity demonstrates how ReportParameters and dynamic record limits are applied effectively.
