Creating Transform leads to duplicate rules detected
While completing the exercise for Building Intent Driven Interfaces, I came upon the following error while attempting to run and test my case:
The body of the solution suggested that my data transforms I created some lessons back may have been incorrectly configured so I deleted both of the transforms I created (pySetFieldDefaults and pyDefault in SAE-HRServices-Work class) and recreated the transform closely following the solution. Upon trying again, I found that the same error was appearing. Some Google-Fu lead me to learn to clear my cache and restart the browser which I followed. Trying to run the case again lead me to a new error:
| Status | fail |
| Message | Rule resolution identified 2 versions of the rule with class Rule-Obj-Model and name SAE-HRSERVICES-WORK!PYSETFIELDDEFAULTS |
| Operator ID | Admin@SAE |
| Requestor ID | H0D14692B44F17775312560A485CB2A29 |
| Timestamp | Thu Jan 14 20:44:59 UTC 2016 |
| Engine Version | PegaRULES 7.10 ML6 (coreAssemblyCached_716_259) |
It appears to identify two versions of the rule I created although no alternate version exists. Searching for pySetFieldDefaults shows the rule I created and one for Onboarding and Candidate each. More Google-Fu tells me to delete a row from the database but I am using the servlet exercise system and thus I'm not sure how I would go about that or if I even could. This error is preventing me from moving on through the courses. Any Ideas?
Taylor
