configuring AES nodes
I'm adding a new server to my AES server. My AES version is 3.5 and my Pega Server is 7.1.7 . I have added the lines that the manual said to the prconfig.xml file and prlogging.xml . I already have restarted the both servers but i'm still can not make it work.
The prconfig.xml files is as follow:
?xml version="1.0" encoding="UTF-8"?>
<pegarules>
<!-- This is a minimum format prconfig.xml file. Only the settings which are required to access settings in the database are included.
All other settings which were formerly located only in this file are now Data-Admin-System-Settings. -->
<env name="initialization/settingsource" value="merged" />
<env name="database/databases/PegaRULES/dataSource" value="java:comp/env/jdbc/PegaRULES"/>
<env name="database/databases/PegaDATA/dataSource" value="java:comp/env/jdbc/PegaRULES"/>
<!-- Health Pulse -->
<env name="Identification/SystemName" value="Pega7Sandbox" />
<env name="management/enabled" value="true" />
<env name="management/interval" value="120" />
<env name="management/notifications/appender" value="ALERT-AES-SOAP" />
<!-- Most nodes have a 'default' classification and for these nodes, no additional changes need to be made to this file. However,
if this is node has a non-general purpose, for example: 'Agent', then the node classification setting should be added to this file. -->
<!--env name="initialization/nodeclassification" value="Agent" / -->
<!-- Settings can still be put in this file. If they are, then the value in this file will override the value in the database
for this node. This is useful for settings which are specific to this node and should not be shared by multiple nodes on this
system. -->
Pegasystems recommends that you use Application Server connection pooling to the database for Websphere and
Weblogic. These examples are provided if you need to use Pega Connection Pooling for Tomcat or for testing purposes.
If you are using Application server connection pooling, there is no longer a need to edit this file.
****The new format for this file is only valid if you are using Application Server connection pooling. If you are not, please replace
this file with an older version. ***
Oracle 10g (Type 4) oracle.jdbc.OracleDriver jdbc:oracle:thin:@serverName:1521:db
IBM DB/2 Type 4 com.ibm.db2.jcc.DB2Driver jdbc:db2://serverName:port/dbName
SQL Server 2005 com.microsoft.sqlserver.jdbc.SQLServerDriver jdbc:sqlserver://serverName:1433;SelectMethod=cursor;SendStringParametersAsUnicode=false
<env name="database/drivers" value="com.microsoft.sqlserver.jdbc.SQLServerDriver;oracle.jdbc.OracleDriver" />
<env name="database/databases/PegaRULES/url" value="jdbc:sqlserver://serverName:1433;SelectMethod=cursor;SendStringParametersAsUnicode=false" />
<env name="database/databases/PegaRULES/userName" value="a_username" />
<env name="database/databases/PegaRULES/password" value="a_password" />
<env name="database/databases/PegaDATA/url" value="jdbc:sqlserver://serverName:1433;SelectMethod=cursor;SendStringParametersAsUnicode=false" />
<env name="database/databases/PegaDATA/userName" value="a_username" />
<env name="database/databases/PegaDATA/password" value="a_password" />
</pegarules>
and the prlogging.xml is as follow:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
<log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/" debug="false">
<appender name="ASYNC" class="com.pega.apache.log4j.AsyncAppender">
<param name="BufferSize" value="512"/>
<param name="Blocking" value="false"/>
<filter class="com.pega.apache.log4j.varia.LevelMatchFilter">
<param name="LevelToMatch" value="ALERT"/>
<param name="AcceptOnMatch" value="false"/>
</filter>
<appender-ref ref="CONSOLE"/>
<appender-ref ref="PEGA"/>
<appender-ref ref="EXCEPTION-AES-SOAP"/>
</appender>
<!-- <appender name="ALERT-ASYNC" class="com.pega.apache.log4j.AsyncAppender">
<param name="AcceptOnMatch" value="true"/>
</filter>
<filter class="com.pega.apache.log4j.varia.DenyAllFilter"/>
<appender-ref ref="ALERT-PERFORMANCE"/>
<appender-ref ref="ALERT-SECURITY"/>
</appender> -->
<!-- Primera Agregada -->
</filter>
<appender-ref ref="ALERT"/>
<appender-ref ref="ALERT-AES-SOAP"/>
</appender>
<!--Segunda Agregada -->
<appender name="ALERT-AES-SOAP" class="com.pega.pegarules.priv.util.SOAPAppenderPega">
<param name="EndPointURL" value="http:// Proprietary information hidden:8080/prweb/PRSOAPServlet" />
<param name="Mode" value="ALERT" />
<param name="AllowLiveChanges" value="true"/>
<param name="OutputEnabled" value="true"/>
<layout class="com.pega.apache.log4j.PatternLayout">
<param name="ConversionPattern" value="%m%n" />
</layout>
</appender>
<!--Tercera Entrada -->
<appender name="EXCEPTION-AES-SOAP" class="com.pega.pegarules.priv.util.SOAPAppenderPega">
<param name="Mode" value="exception" />
<param name="AllowLiveChanges" value="true" />
<param name="ExceptionsOnly" value="true" />
<param name="ConversionPattern" value="%d{GMT}*%Y{instance_id}*%t*%c*%X{RequestorId}*%X{pegathread} *%X{app}*%X{userid}*%X{stack}*%m%n"/>
</layout>
</appender>
<!--Cuarta Entrada -->
<!-- <appender name="ASYNC" class="com.pega.apache.log4j.AsyncAppender">
</filter>
</appender>
<appender name="ALERT-PERFORMANCE" class="com.pega.apache.log4j.AsyncAppender">
<filter class="com.pega.pegarules.priv.MDCMatchFilter">
<param name="TagToMatch" value="alertType" />
<param name="StringToMatch" value="security" />
</filter>
</appender>
<appender name="ALERT-SECURITY" class="com.pega.apache.log4j.AsyncAppender">
</filter>
<appender-ref ref="ALERTSECURITY"/>
</appender>
<appender name="CONSOLE" class="com.pega.apache.log4j.ConsoleAppender">
<param name="ConversionPattern" value="%d [%20.20t] [%10.10X{pegathread}] [%20.20X{tenantid}] [%20.20X{app}] (%30.30c{3}) %-5p %X{stack} %X{userid} - %m%n"/>
</layout>
</appender>
<appender name="PEGA" class="com.pega.pegarules.priv.util.DailySizeRollingFileAppenderPega">
<param name="FileNamePattern" value="'@{web.tmpdir}/PegaRULES-'yyyy-MMM-dd'.log'"/>
<param name="MaxFileSize" value="50MB" />
</layout>
</appender>
<appender name="ALERT" class="com.pega.pegarules.priv.util.DailySizeRollingFileAppenderPega">
<param name="FileNamePattern" value="'@{web.tmpdir}/PegaRULES-ALERT-'yyyy-MMM-dd'.log'"/>
</layout>
</appender>
<appender name="ALERTSECURITY" class="com.pega.pegarules.priv.util.DailySizeRollingFileAppenderPega">
<param name="FileNamePattern" value="'@{web.tmpdir}/PegaRULES-ALERTSECURITY-'yyyy-MMM-dd'.log'"/>
</layout>
</appender>
<appender name="BIX" class="com.pega.pegarules.priv.util.DailySizeRollingFileAppenderPega">
<param name="FileNamePattern" value="'@{web.tmpdir}/PegaBIX-'yyyy-MMM-dd'.log'"/>
<param name="ConversionPattern" value="%d [%20.20t] [%20.20X{tenantid}] [%20.20X{app}] (%30.30c{3}) %-5p %X{stack} %X{userid} - %m%n"/>
</layout>
</appender>
<category name="com.pega.pegarules.data.internal.access.ExtractImpl" additivity="false">
<priority value="info"/>
<appender-ref ref="BIX"/>
</category>
<category name="com.pega.pegarules.data.internal.access.ExtractParameters" additivity="false">
</category>
<category name="com.pega.pegarules.data.internal.access.DatabaseUtilsCommonImpl" additivity="false">
</category>
<!-- Provided as an example for how to enable messaging for PRPC or java class.
<category name="Rule_Obj_Activity">
</category>
<category name="com.pega.pegarules.engine.context.InitialConfiguration">
</category>
<!-- Provided as an example for how to enable logging for LookupLists in a separate file
<appender name="LOOKUPLIST-STAT" class="com.pega.pegarules.priv.util.FileAppenderPega">
<param name="FileNamePattern" value="'PegaRULES-LLCSTAT-'yyyy-MMM-dd'.csv'" />
</layout>
</appender>
<category
name="com.pega.pegarules.session.internal.stats.lookuplist.LookupListStats">
<priority value="info" />
<appender-ref ref="LOOKUPLIST-STAT" />
</category>
<root>
<priority value="alert"/>
<appender-ref ref="ASYNC"/>
<appender-ref ref="ALERT-ASYNC"/>
</root>
</log4j:configuration>
Hello Napoleon,
I see that you have engaged Pegasystems Global Customer Support (GCS) regarding this issue. This is correct path to report these kinds of product operation problems, and ensures we can do proper investigation into the issue and continuous product improvement based on issues found and resolved. Please continue to work with GCS on this issue and future product operation problems you encounter. Thank you! -Ian
