Adqura
Last activity: 27 Feb 2017 14:16 EST
Configuring nodes to run selected agents
We are going through the below link with regards to agent runs
https://pdn.pega.com/configuring-nodes-run-selected-agents/configuring-nodes-run-selected-agents
If few agents configured using IncludeAgents does it override or complement agent schedule settings
Does it also mean that the agents configured above should not be available on other nodes to start/stop by the user from SMA.
Is this setting picked/check only on the node startup.
