Using Kibana to view Util node logs
My system is running Pega 7.3.0 with 1 Util node and multiple Web nodes on the cloud. I am trying to use ELK (Kibana) to view the logs. I wrote a message from an activity running on the Util node (via an agent) but Kibana will not display it. What do I have to do to enable Kibana to show the Util node log? How do I know for sure that it is showing the logs from all Web nodes? Note that I can see the log message in Kibana if I run the activity manually (it is being run on a web node in that case).
