Base Rule and Date Ranged Circumstancing - Different Ruleset Versions
Hi All, ( In PRPC V6.1) I have a base rule in Version RuleSet : 01-09-31.
I have a DateRanged version of this rule that ends on Dec 30, but it is in a higher Ruleset viz. RuleSet : 01-09-32.
I need the base rule to fire on Dec 31. Will the above configuration work or do both the rules NEED to be in the same highest versioned ruleset i.e 01-09-32 ?
On Dec 31st, will the Base rule in the lower versioned Ruleset 01-09-31 fire or does the Base Rule NEED to be in the SAME ruleset as the circumstanced rule i.e in RuleSet : 01-09-32.
