SINARMASMSIGLIFE
SINARMASMSIGLIFE
ID
SINARMASMSIGLIFE
Posted: Nov 13, 2017
Last activity: Nov 23, 2017
Last activity: 23 Nov 2017 22:25 EST
Property-Rule Ruleset Version In Resolution Ruleset
hi,
in application development, my team mostly uses localize value for static value( Base on Requirement user ), and then After development continues into phase 2, the user asks to change the contents of the local value. (i attach example property using Prompt values )
Is property-rule can be upgraded to the latest version (to the unlock version of the ruleset version) ?? because when i try, there is warning message :
"A property of this name already exists for the chosen applies to class. It is either inherited from a parent class or in a different ruleset than the one chosen. Duplicate property definitions can negatively impact system performance.
Do you want to create anyway?"
thanks
