Virtusa
Last activity: 8 Aug 2017 12:42 EDT
Move Rules from one ruleset version to another
Hi ,
Is there a way to copy/move "selected" rules from one ruleset version to another ?
Ex : RuleSet A : 01-01-01 has 50 rules
now i need to move few rules (say 20 of them) to RuleSet A : 01-01-02.
Thanks.
Virtusa Consulting UK
Virtusa
Thanks , I will try that .
Between , apart from the process in the link is there any straight forward way ? i mean like refractor wizard ...
No, there is no wizard available for cherry picking the rules and move.
Hi Adithya,
Can you try 'Copy/Merge Ruleset' tool?
Check below link:
https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
Susan
Virtusa
we cannot cherry pick the rules in "Copy/Merge" tool . i need only few selected rules to be moved .....
Found this on one of the posts on pdn. Please try the Following:
1. Create a Product Rule for the Particular Rule Set that you would like to move.
2. Create a zip
3. Delete that Particular ruleSet
4. Imprt the zip and click Show Contents
5. Imprt the rules that you would like to import.
6. Use the Rule Maintenance wizrd to move these rules to where you want to move.
7. Delete the Version again
8. Imprt the zip again and dop show contents
9. Import the Rules that you want to have in the same version.
Let us know how did it go!!
Virtusa
There does not seem to be any OOTB feature for your requirement.
2. Create a zip
