Self
Last activity: 8 Sep 2015 8:43 EDT
Create/Delete/Update a Ruleset Version takes time as their are 1100 different rule set versions available to render in RuleSet Rule Form
Create/Delete/Update a Ruleset Version takes time as their are 1100 different rule set versions available to render in RuleSet Rule Form.
Is there an alternate way to let the system load only major versions specified.
Example: My application contains Major Versions 01, 02, 03, 05 and 15. Can we specify preferences to load only major version - 15 as most of the time we want to focus on 15-01-XX till 15-99-99.
Hi Ashwin, Good Morning!
Could you kindly comment on the need to have all lower versions when the application rule is pointed to major version 15-XX-XX
https://pdn.pega.com/reuse-and-version-management/about-ruleset-versions
true, having 1100 ruleset versions would run into slowness issues as you mention.
Please share your comments/thoughts, Thank you!
psahukaru
