Commonwealth Bank Of Australia
Last activity: 29 Jun 2022 4:56 EDT
How to Bulk delete Ruleset versions
Hi Pega Product Team,
https://collaborate.pega.com/question/delete-ruleset-versions
Any update on this enhancement request, i think it is raised almost 6 years back, I hope we have a solution in the latest versions like 8.4, 8.5 or 8.6. If so, could you please let us know the navigation and help us out here.
We really need this functionality because, we have code base spanning across the RSV 01-01-01 to 01-99-99 which is containing 65K rules, we recently skimmed to 03-01-01 where the end result of rule count is 23K. Now we don't want to retain the the earlier code base, but we don't have an easy way to delete 10K RSV, we really want a solution to this problem, could you please guide us in the right direction.
If there is no proper solution, could you please let us are there any work arounds available? We thought of deleting from DB, but again as rules are getting saved in different tables we are not sure of what are the different tables we need delete the records. If at all there are list of tables need to be deleted which is equivalent of RSV deletion from UI, please specify which will be great help for us, but just want to remind that we want to do the same exercise on production environment as well.
Please help us out here, as this only one of the application I am talking about, we do have multiple applications with the same scenario. Thanks in advance for the same.
