Automation of Deployment process, possible??
Guys,
Was wondering if there is any option to automate deployment process as soon as developer checks in the code?
Guys,
Any ideas?
Sayali,
Thanks a lot for your post.
You posted your question in the Pega Academy Support Forum. Since your question is not related to any course it is recommended you reach out to Pega Product Support instead: https://pdn.pega.com/about-customer-support
Marco.
Thanks Marco for your reply.
would Migrate product wizard be of use?
Without using GUI we should be able to deploy build to higher env.
HI,
The PRPC utility command line tool is part of the software distribution zip file and can be used to import and export rules
There are two scripts available:
Damien
