Cognizant
Last activity: 15 Jun 2015 14:07 EDT
Automatic closing of child tabs on close of the parent tab
We have a scenario in our pega 7 CPM application where in we can create a child interaction from the parent interaction. All the interaction work items(parent as well as the children) open up in different tabs. The requirement is to close all the child work item tabs when the parent interaction case is wrapped up.
I tried opening the child cases and forcibly resolving them followed by calling DoClose on each of the child item's from post wrap up of the parent case but that is not working.
Is there any other way that this can be achieved?
For best practices on how to implement and extend interactions please refer to the CPM Implementation Guide, Chapter 5 focuses on the interactions. The implementation guide may be downloaded from the PDN Products menu select Customer Service and then Pega Customer Service. You will see the guides for the various versions. Further, your question also involves a design question of significant scope that requires a more nuanced answer. Based on your particular example I suggest that you reach out to Pega Consulting for further assistance.
Lu
