Auto save assignment on change of field for Constellation application
Introduction
This document describes the steps to load the custom dx component which will enable save of assignment on change of a field.
Steps:
1. Create custom dx component, samples here: choose type as any form/scalar field eq., TextInput https://github.com/pegasystems/constellation-ui-gallery
Custom dx component builder:
2. It is a background processing component which going to connect to field change and saves the assignment.
3. Add component to current assignment form view.
Sample
Code:
Below example assumptions FirstName field change will save the assignment.
import { useEffect } from 'react';
export default function SaveAssignmentComponent(props) {
const { getPConnect } = props;
const pConn = getPConnect();
const saveAssignment = () => {
/* Get the current case etag */
const etag = pConn.getValue("caseInfo.headers.etag");
const assignmentID = pConn.getValue(
PCore.getConstants().CASE_INFO.ASSIGNMENT_ID
const actionID = pConn.getValue(
PCore.getConstants().CASE_INFO.ACTIVE_ACTION_ID
? pConn.getValue(PCore.getConstants().CASE_INFO.ACTIVE_ACTION_ID)
: pConn.getValue(PCore.getConstants().CASE_INFO.ASSIGNMENTACTION_ID);
/* Payload to resolve dx api */
const payload = {
queryPayload: {
assignmentID,
actionID,
body: {
content: {
/* Property or field name */
FirstName: pConn.getValue(".FirstName"),
headers: {
/* etag as part of header */
"if-match": etag,
/* Triggers save dx api */
PCore.getRestClient()
.invokeRestApi("save", payload)
.then((response) => {
/* Upon successful, update the latest etag. */
const updatedEtag = response.headers.etag;
PCore.getContainerUtils().updateCaseContextEtag(
pConn.getContextName(),
updatedEtag
useEffect(()=> {
const subId = Date.now();
/* Register field change event. */
PCore.getCascadeManager().registerFields(
pConn.getPageReference(),
[".FirstName"],
saveAssignment,
subId
/* Unregister fields */
return () => {
PCore.getCascadeManager().unRegisterFields(
[".FirstName"],
saveAssignment,
subId
return null;
