Evonsys
Last activity: 1 Nov 2024 8:27 EDT
Constellation View auto refreshing after change of pyCountry
In Constellation i have added a data type "Data-Address-Postal" to my application
2) Created a field "Embedded data"
3) Add the created field in a view
as soon as we add the field the whole address is getting populated in the view, i have below questions
1) after adding the Address field, How pega is adding the view (not the primary fields)
2) at run time as soon as the country field changed the below fields are also getting updated, How is it getting changed/refreshed without any custom components.
i did not see any custom component added in OOTB, any one know How pega is doing this auto refresh after the change of the country field data
@Mani Bharghav
You can create a view A - which has a view B with country dropdown and one view for each country code for example - View_IND. Now set the visibility of View_IND as country = "INDIA". This way different views will load for the different values selected in the country dropdown.
Add view A to your reference field.
