TCS
Posted: August 24, 2015
Last activity: April 6, 2018
Last activity: 6 Apr 2018 19:26 EDT
-542 error on CPM upgrade from 6.2 sp3 to 713
We are upgrading CPM from 6.2 sp3 to 713. Our Database is DB2ZOS. We just performed an upgrade from Pega 6.2 sp1 to Pega 7.1.8 . As part of the CPM upgrade guide, we executed the generateddl.sh script with the correct parameters as instructed.
When generated ddl was executed, the following error appeared:
ALTER TABLE XXXXXX.pca_rating_knowcont,
ADD CONSTRAINT pca_rating_knowcont_PK PRIMARY KEY
EntityKey,
RatingEntity
DSNT408I SQLCODE = -542, ERROR: RATINGENTITY CANNOT BE A COLUMN OF A HASH
KEY, PRIMARY KEY, A UNIQUE CONSTRAINT, OR A PARENT KEY BECAUSE IT CAN
CONTAIN NULL VALUES
Should RATINGENTITY column be defined as NOT NULL to allow it to be part of the primary key, as a column cannot be NULL and be part of a primary key? If a column can be NULL then it could allow duplicate entries and a primary key has to be unique.
