Truviq Systems
Last activity: 22 Feb 2016 8:49 EST
Assignment Not Found - Flow Removed
We are facing "(FlowName) - Assignment Not Found - Flow has been Removed" issue instantly.
May be because of the case is not found in Assigned WB or WL. But the case is moving forward towards resolution.
We are performing FA by resuming flow using ResumeFlow Activity. Everything is working fine. Sometimes we are facing above issue.
FixProblemAssignments we used as workaround.
Please suggest me.
-- Chaitanya
Please check all of the following places, and if you have any obj-saves, obj-deletes, or commits that are referring to your work object or assignment, remove them:
assignment sla activity
work object sla activity
other agent activity
listener activity
flow action pre and post activities
utility shape activities
The reason to remove the obj-save, obj-delete, and commit operations from those places if they refer to your work object or assignment is that the core level Pega code already does the appropriate operations, and if you introduce extra ones, although most of the time it will work, if there is ever a rollback, issues like the one you are having (flow-removed error) can occur.
/Eric
