Issue with Layout container after upgrade to 8.7.3
After system is upgraded from 7.3.1 to 8.7.3 ,started seeing a number in space of left padding of UI containers..
***Edited by Moderator Marije to add Support Case Details ***
@BRAHMESH@ did you go through the troubleshooting articles?
Please provide screenshots of the extra blank space you are facing. Also, you can
- In the layout properties check if you are using any container format other than "none".
- Try using different layout styles. Go to skin rule and remove the padding and margins.
- Use Stacked dynamic layouts
- In presentation tab change the space between dynamic layout.. Choose All items in Bottom drop down
Please check the UI documentation. - Configuration options for layouts
If you need a more in-depth review I suggest that you log a support incident for this. Please provide the INC reference if you do this.
