Swedbank AB
SE
Last activity: 8 Mar 2019 11:42 EST
Server is hung on runing of recreateindexesforclass utility
We are adding additional columns to index table from work class blob. So We are running recreateindexesforclass utility on production existing data . But is system is hanging for 10 k records also. In log trace we could see issue in recreateindexesforinstance activity step 2.
ThreadMonitor W WSVR0605W: Thread "WebContainer : 4" (xxxxx) has been active for 628772 milliseconds and may be hung. There is/are 1 thread(s) in total in the server that may be hung
We would like to know the possible root cause.
Deva.
***Updated by moderator: Lochan to tag SR to post***
Upon reviewing the associated SR, I see that HFIX-36906 was provided.
Did that resolve this for you?
FR
Are you doing it with the landing page or with PRPCUtils?
Swedbank AB
SE
from designerstudio
Hi Deva,
Did you get a chance to look at thred-dump that may have been generated in the rules logs.
Issue might be with connectivity if I have to take a guess.
Ujjwal
Swedbank AB
SE
Thanks for response. We could see below log snippet from thread dump. But we could not root to DB team as we are not sure what is the excact issue . Please share your thoguhts on this .
"WebContainer : 1" Id=458 in RUNNABLE (running in native)
BlockedCount : 70, BlockedTime : -1, WaitedCount : 269108, WaitedTime : -1
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(SocketInputStream.java:165)
at java.net.SocketInputStream.read(SocketInputStream.java:134)
at oracle.net.ns.Packet.receive(Packet.java:311)
at oracle.net.ns.DataPacket.receive(DataPacket.java:105)
at oracle.net.ns.NetInputStream.getNextPacket(NetInputStream.java:305)
at oracle.net.ns.NetInputStream.read(NetInputStream.java:249)
at oracle.net.ns.NetInputStream.read(NetInputStream.java:171)
at oracle.net.ns.NetInputStream.read(NetInputStream.java:89)
at oracle.jdbc.driver.T4CSocketInputStreamWrapper.readNextPacket(T4CSocketInputStreamWrapper.java:123)
at oracle.jdbc.driver.T4CSocketInputStreamWrapper.read(T4CSocketInputStreamWrapper.java:79)
at oracle.jdbc.driver.T4CMAREngineStream.unmarshalUB1(T4CMAREngineStream.java:426)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:390)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:249)
at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:566)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:215)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:58)
at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:943)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:929)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1034)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3820)
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3867)
- locked oracle.jdbc.driver.T4CConnection@cf38e949
at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeQuery(OraclePreparedStatementWrapper.java:1502)
at com.ibm.ws.rsadapter.jdbc.WSJdbcPreparedStatement.pmiExecuteQuery(WSJdbcPreparedStatement.java:1220)
at com.ibm.ws.rsadapter.jdbc.WSJdbcPreparedStatement.executeQuery(WSJdbcPreparedStatement.java:738)
at com.pega.pegarules.data.internal.store.DatabasePreparedStatementImpl.executeQuery(DatabasePreparedStatementImpl.java:395)
at com.pega.pegarules.data.internal.access.Opener$1.getResultPageFromDatabase(Opener.java:753)
at com.pega.pegarules.data.internal.access.Opener$1.action(Opener.java:721)
at com.pega.pegarules.data.internal.access.Opener$1.action(Opener.java:718)
at com.pega.pegarules.data.internal.store.DataStoreManager.readInTransaction(DataStoreManager.java:70)
at com.pega.pegarules.data.internal.access.Opener.openData(Opener.java:789)
at com.pega.pegarules.data.internal.access.Opener.open(Opener.java:2221)
at com.pega.pegarules.data.internal.access.DatabaseImpl.open(DatabaseImpl.java:2508)
Deva
Hi Deva,
Thanks for filtering out the runnable thread for me!
Yes from this its clear that there are issues with Slow DB Here.
Ujjwal
Swedbank AB
SE
Hi Ujjwal,
Thanks for your reply. We are also getting lot of PEGA0019 alerts. We have already raised SR-59819.
Can you please have look.
Deva.
While going through our posts that have SRs on them, I looked up your SR referenced here: SR-59819 and that SR is from 2011. Could you verify for me the SR that you raised on this please?
Thank you!
Swedbank AB
SE
Please find below SR.
SR-C59819: Pega0019 alerts on production , while using Mashup
Truist Financial Corporation
Has this issue been resolved? Could you post the solution please, if the above has been resolved?
Swedbank AB
SE
We have completed Utility with very less records but issue what we have raised in SR still persists. We did not got root cause of PEGA0019 yet.
