Bankofamerica.com
Last activity: 23 Aug 2018 19:06 EDT
Error runing the Deployment file in HVD machine
For window application automation. I have two configuration files , first file contains App Path(local machine) value for windows application.
second file contains the Application Path value for HVD machine. I have deployed solution, when I run HVD machine version of deployment file in HVD machine.
I got blow error message. find the attached error message. Can you some one check and advise how to fix this issue?
Error starting Design Component: application name: Project may not operate correctly.
Unable to start process applcation.exe Start process injected "application exe path" failed.
