Accenture
Last activity: 27 Jun 2024 6:47 EDT
The Real-Time Data Grid (RTDG)
The Real-Time Data Grid (RTDG) and what is the use of this.
***Edited by Moderator Marije to change type from General to Product, added Product details and Capability tags****
Reply
Updated: 27 Jun 2024 6:47 EDT
Eclantiqx Digital Private Limited
Hi Sudha,
Assign the RTDG node type to two Pega Platform nodes to retrieve the large amounts of VBD data through a VBD query.
- In the header of Dev Studio, click Configure > Decisioning > Infrastructure > Services > Real-time Data Grid.
- In the Real-time data grid nodes section, click Edit settings.
- In the Service settings section, configure the RTDG service:
- In the Cluster port field, specify the VBD node cluster port.
- In the Allocated memory (mb) field, enter the amount of memory in megabytes (MB) allocated to the service operations.The default amount is 1,024 MB.
Editing real-time data grid settings
- In the Planner settings section, configure the Visual Business Director (VBD) planner:
- In the Poll interval (seconds) field, enter the frequency for querying the server for new data.
The default frequency is 10 seconds.
Hi Sudha,
- Optional: To edit the maximum number of 3D objects that the VBD planner draws on the main scene, in the Maximum objects at current dimension levels field, enter an integer value.
The total number of 3D objects is calculated by multiplying the number of values on the y-axis by the number of values on the x-axis. For example, if the scene has 16 values at Group level (y-axis) and 4 values at Direction level (x-axis), the total number of 3D objects is 64.
- Click Submit.
The Real Time Data Grid (RTDG) service performs historical analysis and forecasting for your next-best-action strategies.
More info is available here: Configuring the Real-time Data Grid service (pega.com)
Accenture
I'm not able to retrieve large amounts of VBD data through a VBD query how can we get the results.
Accenture
Hi Philip,
I'm not able to retrieve the large amounts of VBD data through a VBD query.
Hi Sudha,
Hi Sudha,
- Click Submit.
