Issue
Unable to modify the default hardcoded text or label values that are used by application base locale in the Constellation UI.
Example scenarios:
- Changing to
- Changing to
- Changing to
- Modifying the Successfully Submitted! message in the toast popup
Symptoms and Impact
User is unable to change terminology or text value as per their guidelines. The default text value remains unchanged.
Steps to reproduce
Attempt to change a default text value by saving a field value.
Explanation
The reported behavior is as per the Constellation UX system configuration. The Constellation UX system configuration is different from the traditional UI. The text values or terminologies are editable in the traditional UI by leveraging rule resolution of field values. For example, in the traditional UI, a user would have saved the relevant field value in the Application rule set and would have updated the text to what is required.
Pega believes that part of Constellation’s value proposition is consistency in experience across the application portfolio, so the application users know what to expect. For example, it is inconsistent if the widget is named in one application but in another application and may be in another application.
Solution
Infinity 25 allows users to customize some text such as labels, instructions, and so on by using dynamic text rules.
For more information, refer the following articles:
Environment
Version found in
Any Constellation environment
@Preethi_K
To change out-of-the-box labels in Constellation, can we use field values in the specific application? And can we generally localize Constellation UX system configurations into different languages?
