Applies to Pega Platform versions 6.2.SP2 through 8.3.1 and Pega Business Intelligence Exchange versions 7.3 through 8.4
Common issues
Recognize the common symptoms and errors of Business Intelligence Exchange (BIX) for on-premise environments. Understand the explanations (root causes) of these symptoms and how to resolve or prevent problems.
Ensure that you have specified the configuration settings correctly.
If you are running BIX for on-premise environments, you can run BIX extracts from the command line. Properly configured settings in the prbootstrap.xml and prconfig.xml files are required. in these files when booting the Pega engine using these file settings. For more information, see
You can run BIX for on-premise environments using the command line or using an agent.
You can also run extracts manually from the Extract rule.
Customized agent does not run, runs on the wrong node, and other issues
Generated CSV Extract or Manifest file cannot be parsed
Java SQLException for schema generation
Symptoms
A customized agent that uses the activity pxExtractDataWithArgs to run a BIX extract for a specific class can trigger the following symptoms:
- The agent does not run or runs at the wrong time.
- Agent is run on the wrong node.
- Selected class or rule does not exist.
The Extract rule <ClassName>!<RuleName> does not exist. Please check the classname and the extract rule name.
- Command-line parameter string supplied to activity is invalid.
Invalid pyArgs specified
Explanation
There will be a dedicated node for batch processes like BIX that will not participate in load balancing for the cluster. The agent should always run on that node.
Solution
To resolve custom agent problems, in the Admin Studio, verify the following information:
- Agent status and last run information
- Node and respective Agent information
- The Class name and the Extract rule name
- A valid command-line parameter provided to the activity pxExtractDataWithArgs
Query Timeout Exception
Symptom
An Extract Rule fails with a Query Timeout Exception.
Explanation
An Extract Rule fails with a QueryTimeout Exception when the rule is run against a database table with a significantly higher number of records than usual.
Solution
To resolve Query Timeout Exceptions, increase the timeout by setting the DASS:
DASS NAME: BIX/selectQueryTimeout
RULESET : Pega-RULES
Symptom
A generated CSV Extract or CSV Manifest file could not be parsed by a downstream process. For example, a File Listener is using a parse delimiter rule.
Explanation
CSV parsing failures can occur when the Parse Delimiter rule in Pega is used to interpret the CSV extract. Because the default delimiter used to generate the extract is “, ” (read as comma space) , the space might not be properly interpreted.
Solution
To resolve CSV parsing failures, set the delimiter “,” explicitly using the command line option -l.
See the following articles:
Running a BIX command-line extraction in on-premises systems
BIX parameters and command-line arguments
BIX extraction process does not generate a manifest file containing data description language (DDL) for SQL databases
Symptom
An extraction process that uses Database Schema as the extract file format that has enabled a manifest (DDL) file to extract to a target database produces the following error in the log files:
Error: 2020-06-02 19:23:24,783 [ PegaRULES-Batch-4] [ STANDARD] [ ] [ CLM:01.01.27] (ernal.bix.BIXManifestWriterDDL) ERROR G01292608
Explanation
The Extract rule for SQL database extractions uses dbo as the default schema name. Pega Platform does not provide the option to change the default schema name for SQL extractions in a target database. If your target SQL database schema does not use dbo as the schema name, Pega Platform produces the error described above during the extraction process when attempting to generate a manifest file in the schema.
Solution
In the prconfig.xml file, add the following setting to change the default schema from dbo to the name of your schema into which Pega Platform extracts the manifest file:
<env name="database/databases/<TargetDBName>/defaultSchema" value="<SchemaName>"/>
Replace <TargetDBName> with the name of the target database in which you want Pega Platform to generate the manifest file.
Replace <SchemaName> with the name of the schema to which Pega Platform generates the manifest file in the target database.
For more information, see Configuring the target database for BIX command-line extractions in on-premises systems.
Symptom
Schema generation for the target database table fails with a Java SQLException.
Error: “java.sql.SQLException: A PRPC-supported database platform was not found:”
Explanation
When extracting to a database, the destination database must be supported by the Pega Platform version that you are using. The Pega Platform does not support MySQL:
Pega Infinity Platform Support Guide
Solution
To prevent database errors such as SQLExceptions, do not attempt to extract data to a database application that the Pega platform does not support. Always refer to the Pega Platform Support Resources.
System time zone ignored
Symptom
BIX extraction does not consider the system time zone when the Extraction command line options -u / -U or -d/-D are used.
Explanation
While passing the value for -u /-U command line option, you forgot to include the tIme zone information. The time zone is the locale that is set on the thread or the default locale of “en_US” and the timezone of “EST”.
Solution
To prevent time zone issues with your extracted data, remember to include time zone information in your command line options for -u /-U. For example, 20110823T164017.000 GMT.
See BIX parameters and command-line arguments.
Specifying configuration settings for BIX in on-premises environments
- Use the individual prconfig.xml files for each Pega Platform server.
- Use Data-Admin-System-Settings (DASS) instances for each cluster.
Setting Location |
Setting Name |
Description |
Default Value |
| prconfig | |||
prconfig |
Compatibility/BIXUseOptimizedClipboardXML
Optimizes the clipboard to facilitate extracting a large number of class instances to XML |
true |
prconfig |
Compatibility/BIXdisableForwardChaining Configuring optional prconfig.xml settings in on-premises systems |
Disables forward-chaining calculations of properties when loading the clipboard for BIX extract |
true |
prconfig |
Compatibility/BIXDisableBackwardChaining Configuring optional prconfig.xml settings in on-premises systems |
Disables backward chaining of properties when loading the clipboard for BIX extracts |
true |
prconfig |
bix/retainOriginalFileNameForCSV |
Keeps the original file name for the CSV output. The default value (false) replaces the hyphen (‘- ‘) in the original file name with an underscore (‘_’). |
false |
prconfig |
bix/removeAdditionalColumnsInCSV
Example: <env name="bix/removeAdditionalColumnsInCSV" value="pxExtractIdentifier,pxExtractDateTime"/> |
Removes the specified columns from the generated CSV output file.
prconfig |
bix/useHighThroughputDownloadForCSV Business Intelligence Exchange (BIX) 8.1 User Guide, the sections Configuring optional prconfig.xml settings and BIX performance recommendations. |
Enables high-throughput data downloads for BIX extracts from a BLOB- less class table in a Postgres database for CSV type output. |
true |
prconfig |
bix/getClearTextWhileExtraction |
Displays encrypted data that is stored in the BLOB as clear text when the data is extracted. The default value (false) disallows clear text and keeps data encrypted. |
false |
DASS |
BIX/generateXSDForAllProperties
Ruleset: Pega-RULES
Generates XSD when GetAllProperties is selected for the XML type output. The default value (false) disallows the generation of XSD for GetAllProperties. |
false |
DASS |
Ruleset: Pega-RULES |
Specifies the time in seconds before the query to fetch records from the source database times out. The default value is 30 seconds. |
30s |
DASS |
BIX/setCommandLineDelimiterForCSVManifestFile
Ruleset: Pega-RULES
Running a BIX command-line extraction in on-premises systems |
By default, the command line option -l is applicable for the CSV output file only. Change the default value of this DASS to true to override the default setting and enable this option for the CSV Manifest as well. |
false |
