Prerequisite
Before you begin using this patch release information, see the information for the minor release, Pega Platform 8.7 Installation and Update Information.
Critical HFIX-A186 prevents potential system stability and data corruption
HFIX-A186 is required to correct a regression defect introduced in Pega Platform™ 8.7.5 whereby, after you update your Pega deployment to Pega Platform version 8.7.5 and import a RAP file, database column population and optimization creates system instability and data corruption. See the Client Advisory (CAD) about this critical hotfix.
After you update to or install Pega Platform version 8.7.5, you must obtain and install HFIX-A186 before you import any RAP file, Pega-supplied or custom.
Be sure to follow this sequence of actions:
- Update to or install Pega Platform version 8.7.5.
- Obtain and install HFIX-A186.
- Import any RAP files, Pega-supplied or custom.
Obtaining HFIX-A186
Find and install HFIX-A186 from the Hotfix Manager page of Dev Studio:
In Dev Studio, click .
For more information, see Apply Pega Platform hotfixes, specifically Installing a hotfix from the user interface.
Alternative: Go to My Support Portal and click . Complete and submit the ticket form.
Release Notes for Pega Platform 8.7.5
There are no release notes for this patch release of Pega Platform 8.7.
See the release notes for the minor release, Pega Platform 8.7.
Resolved Issues for Pega Platform 8.7.5
Resolved Issues – Client-reported issues that were fixed can be viewed by Capability.
If you think that your support case (INC) generated a Resolved Issue, specify the INC ID in the Pega Support Center Search field to find the Pega Platform 8.7.5 Support Document. Then use your browser’s or menu option to find the specific Resolved Issue in the Support Document. (Pega engineers can also search on the Issue ID, a Pega-internal work object.)
Pega Platform 8.7.5 Resolved Issues PDF - All the client-reported Resolved Issues for this release are aggregated in one document. See the link at the bottom of the Resolved Issues Support Document.
Pega Platform changes with update impact - Resolved Issues that require the client to take some action, for example, change a setting, restart the system, and so on.
The Resolved Issues page is different from the Pega Platform changes with update impact.
For more information about the client-reported Resolved Issues, see How to Get Support > Support self-service offerings > Resolved Issues.
Updates and Patches
See Pega Platform 8.7 Installation and Update Information, the section Pega Platform Update Guides.
