Upgrade Issue 7.1.5 to 8.7.5 .
Hi team,
Actually, recently we have upgraded our application 7.1.5 to 8.7.5 .
Here 7.1.5 we have almost text files and paragraphs. That java script code not supported in 8.7.5 version.
That text file we have lot of functions to open modal dialogues in 7.1.5 version.
Those functions not supported in 8.7.5 version. I got this error
“OpenUrlInDialog API and window.showModalDialog are no longer supported. Replace by an auto-generated local action.”
In that function they used below step
var r = window.showModalDialog(strUrl,'',strFeatures);
this is exact code
function UpdateStatusProposal()
var strFeatures = "resizable=yes;status:no;dialogWidth:420px;dialogHeight:300px;help:no;maximize:no;minimize:no;scrollbars:yes";
var strUrl = pxReqURI+"?pyActivity=***--***--***--*** classname.UpdateStatusProposal&pzPrimaryPageName=pyWorkPage";
var oSafeUrl = new SafeURL("A***--***--***--*** classname.LoadSPHarness");
oSafeUrl.put("pzPrimaryPageName","pyWorkPage");
doFormSubmit(oSafeUrl.toURL(), null, null, event);
Hi team,
this is exact code
var oSafeUrl = new SafeURL("A***--***--***--*** classname.GetSOSNumber");
var SOSworkid=httpRequestAsynch(oSafeUrl.toURL(),"post");
if(SOSworkid != "true"){
var sosassign = "***--***--***--*** classname "+ SOSworkid + "!SOSSCREENFLOW";
openAssignment(sosassign,1);}
If you guys also facing same issue with that step in 8.7.5 version. pls help me out.
Otherwise, i need to create local action and use it. Without changing any existing functionality i try to change that step
