Launchpad Quick Links
User Roles for Launchpad
Getting Support at Pega
The Pega Support mission
Your role as a provider
Fulfilling your responsibilities as a client
Creating Support Incidents
Report an Incident
Complete the Support Ticket form
Support Ticket Confirmation
Severity
Advocating for Support Excellence
Related Documents
Support for Launchpad will be provided via our standard My Support Portal (MSP) application.
There are 2 roles available for Launchpad users:
- Provider Admin
- Provider Developer
These roles are created via the Launchpad Admin Portal. As a Launchpad user, you have access to MSP regardless of the Launchpad role assigned to you.
On selecting the Create a ticket button on the MSP homepage, you will be presented with the Create a ticket wizard.
If you have a Launchpad role in addition to an Infinity role (MSP roles outlined in Understanding Support User Roles) you will be presented with an initial screen allowing you to specify which platform you would like to log a ticket against i.e. Launchpad or Infinity.
- Selecting Launchpad takes you directly to Create a ticket wizard
- Selecting Infinity takes you to Create a new support ticket screen (as outlined in Creating a support ticket).
Check out this video for a quick overview on getting Support for Launchpad:
Pega support teams ensure your success, as Pega Launchpad Providers, by fulfilling the core values of their mission:
- Providing world-class technical support on the use of Pega products and services.
- Making it easy, pleasant, and rewarding for you, to work with us.
- Using their skills, experience, and data on the Pega client perspective to drive product and service improvements, including documentation refinements.
Pega support teams operate globally to provide support. See Pega Support Contact Information.
Pega support engineers are software engineers with expertise in Pega products and services and third-party software products such as application servers, relational database software, and integration software.
Support works tickets based on engineer availability and expertise. When responding to tickets, support engineers focus on restoring system operations first. When system operations are restored, they focus on establishing the root cause of the reported problem, immediate remediation, and a path to a permanent solution.
Pega support teams help you eliminate the need for creating a support ticket by contributing to documentation such as Pega Launchpad FAQ and Pega Launchpad documentation.
Your Role as a Provider
As a Pega Provider, you are responsible for fulfilling the following responsibilities in your partnership with Pega teams:
- Acting as frontline support for your subscribers before contacting Pega for incident tickets
- Knowing your Pega deployments and applications
- Providing complete information about your problem or request, including the relevant supporting information (Correlation ID, screen captures, documents)
- Responding promptly to follow-up questions and requests from Pega engineers
- Allowing screen-sharing sessions with Pega engineers
- Keeping track of your support tickets by viewing and downloading reports of the tickets, using the Export to Excel feature in My Support Portal
Requesting Pega support is an intuitive, simplified experience. Using the wizard-like Report an Incident form, you are guided in selecting the type of situation you are experiencing and in describing it using a template. Embedded assistance (tooltips) helps you complete the form. You can create an incident using this process.
An Incident is defined as an unexpected error or event that affects your business, requiring restoration of services in the shortest possible time to reduce loss of business to you.
Reducing time to resolve your support ticket
As a Pega client, you can help reduce the time it takes to resolve your support ticket by submitting concise and complete information.
Report an Incident
There are 2 Incident ticket types available for Launchpad:
Incident Ticket Types |
Description |
Full system outage |
An Incident causing complete system outage for any environment (Development, Testing, Staging, or Production) |
Production impact |
An Incident causing disruption to business as usual, preventing application users from performing their tasks or preventing processes and services from running in the Production environment |
Complete the support ticket form
- Click Create a ticket on the My Support Portal (MSP) Home page.
- The Report an Incident form displays.
- Choose the ticket type that best matches your needs from the Type of incident dropdown.
- Complete the remaining fields on the form and click Continue to move through each section of the form.
- For example, when completing the form for a Full System Outage Incident, you move through form sections called Ticket Details > Environment Details > Contact Details.
- Ticket Details:
- Type of incident
- Short Summary
- Detailed description
- Error Message - be sure to enter the full error message on the screen, including the Correlation ID
- Steps to reproduce
- Environment details:
- Provider - Your account details
- Subscriber - The affected Subscriber details
- URL - The URL of your Provider Admin portal
- Add Attachments - include any screen captures or other supporting documents.
- Contact information
- Contact name
- Phone number / Alternate phone number details
- Country
- Time zone
- Client contact region
- Additional contacts / Bulk add contacts by role
- The fields of the support ticket form differ depending on the type of ticket that you selected.
- For example, when creating a Production Impact incident, follow similar steps. Note: one additional field will be needed: The Feature Impacted. Please set this based on the feature related to the incident.
- Use the tool tips that are provided to guide your information.
- Mandatory fields are marked with an asterisk (*).
- Drop-down selection lists display valid values for the type of support ticket that you chose.
- Some fields have values auto-populated by the system for the type of support ticket that you chose.
- For text box fields, make sure that your descriptions are as complete and concise as possible.
- Click Finish to submit the support ticket.
Support ticket confirmation
- After you submit the support ticket, you see a confirmation message that identifies your ticket ID and displays a View Ticket button.
- The message states that your ticket is being routed to the right support resource, who will contact you shortly.
- Click View Ticket to see your support ticket in My Support Portal.
- All Launchpad support tickets will be entitled Launchpad Incident at the top of the right-hand summary panel in the case view.
- In the Details tab you'll see the Type of Incident, your Provider details, the Subscriber details and the relevant URL
- In the Pulse tab, you'll see two pulse posts on your support ticket:
- The first is an Acknowledgement detailing the date and time that the ticket was created.
- The second is the Initial response, advising you that ticket triage has started.
- You also receive a Notification email, if you have set your Notification Preferences to enable this option. (See: My Support Portal Frequently Asked Questions, Communicating on tickets, for further information on Notification Preferences)
Severity
The severity of your support ticket is assigned even though you did not explicitly select one. Severity is calculated for you by the system based on the qualifiers of the support ticket e.g. the incident type selected. Launchpad Incidents will generally be assigned as a Severity 1 or Severity 2.
The support team might also downgrade your incident to a Severity 3 for further follow up, should the need arise.
Understanding Severity 1 Incidents
Severity 1 indicates that the Pega Service is down, inaccessible, or the service is unusable, resulting in a total disruption to the client. When these conditions exist, the case must be assessed and handled as a Severity 1 situation for all production environments.
Advocating for support excellence
Know how and when to assist the Pega team in complying with their standards for support excellence:
- Ensure that you deliver your action items that the support engineer requests in a timely manner.
- Ask for clarification when the actions requested of you by the support team are unclear.
- Ensure that the support engineer has set clear expectations for when your actions should be delivered.
- Communicate any concerns about meeting expected action dates.
- Hold the support engineer or team accountable for specifying their own action items and when to expect them.
- Understand when updates should be expected based on ticket severity
- Hold the support engineer accountable for providing updates
Related Documents
How to get Support (for Pega Infinity clients)
