Issue
In Pega Platform™, when a user navigates a data grid using a screen reader, row numbers are not announced for columns that contain links. This is a known limitation of Freedom Scientific JAWS, not a defect in Pega Platform.
Symptoms and Impact
Users who rely on a screen reader hear only the Case ID link text when navigating the Case ID column in a data grid. The corresponding row number is not announced.
This behavior affects accessibility for users who depend on screen readers to interpret table data. It may cause confusion when correlating a row's content to its position in the grid.
The issue is consistent with WCAG 2.0 Success Criterion 1.3.1 (Info and Relationships), which requires proper header association in web data tables. However, the failure to announce row numbers when a column cell contains a link is a known JAWS behavior that is reproducible outside of Pega Platform entirely.
Steps to reproduce
- Open an application that displays a list view containing a data grid with a Case ID column rendered as links.
- Enable JAWS (Freedom Scientific JAWS screen reader).
- Navigate to the Home page.
- Use the keyboard to navigate through the Case ID column in the data grid.
- Result: JAWS announces the Case ID link text but does not announce the row number for each cell.
Root Cause
This is a known JAWS behavior. When a grid column contains link content, JAWS does not announce the associated row number. This behavior is reproducible independently of Pega Platform, using the W3C WAI-ARIA Authoring Practices data grid example. Moving a link column to the first column position in that example produces the same omission.
Solution
There is no Pega Platform code change required. This behavior originates in JAWS and is not controlled by Pega Platform.
Local Change (workaround)
No workaround is currently available within Pega Platform. Users may:
- Contact Freedom Scientific to report the behavior or check for a later JAWS release that addresses grid row number announcement for linked columns.
- Reorder columns in the data grid so that the linked column is not the first column, and test whether this changes announcement behavior in their specific JAWS release
References
https://www.w3.org/WAI/ARIA/apg/patterns/grid/examples/data-grids/
