Scenario
The option does not work when the user opens a report.
Error
Error seen in the tracer file:
[Activity pzRDExportWrapper failed to execute][STACK][com.pega.pegarules.pub.PRRuntimeException: Section 'pzRDExportWrapper' execution error on page '' of class 'Rule-Obj-Report-Definition'. : java.lang.reflect.InvocationTargetException at com.pegarules.generated.html.ra_stream_pzrdexportwrapper_8a003fbd0799660a40b7054ec93dd4aa.execute(ra_stream_pzrdexportwrapper_8a003fbd0799660a40b7054ec93dd4aa.java:121)
Explanation
Third-party defect
fontconfig and its dependency packages when missed in Open jdk environment causes this issue.
Environments
The problem was reported in Pega Platform versions 8.7.2 to 8.8.3 environments.
Solution
To resolve the issue, install fontconfig and its dependency packages by following the steps given below.
Open the JDK environment
Run the command
yum install fontconfigor the relevant/comparable command to installfontconfigpackage. -
Restart the server.
Related content
- NPE from sun.awt.FontConfiguration.getVersion using Apache FOP JDK 11 on Linux system
- Tips for troubleshooting Export to Excel issues
@AiswaryaSudhakar Maybe this is also an issue with 23.1.4? We just installed a "E25 Security Advisory (23.1.4)" hotfix and seem to be having the same issue.
