Why cache is maintinaing across jvms in a cluster?
We have PEGA application running in Websphere application server v7 cluster environment. When ever there is an issue with login, we are following a PEGA instruction https://pdn.pega.com/how-clear-websphere-tempwork-directory to clear the cache and delete markup file. I do not understand why we have shutdown all the JVMs in the cluster same time, which make application not available to users. Why the cache is maintained between the jvms instead every JVM has to have its own cache.
