John Deere
Last activity: 15 May 2018 23:31 EDT
Rule cache not in sync across nodes
We are facing an issue in production where the newly deployed rule is getting picked up for one operator and not for the other. After some time, both operators get to use the same rule. We suspect that this is because of rule cache syncing not happening properly.
I went through https://collaborate.pega.com/question/rule-cache-not-sync-multi-node-environment and understood that hazelcast settings in prconfig.xml can cause such problems. Was trying to follow the instructions on this post but I see that hazelcast related settings are not at all mentioned in our prconfig.xml.
Can someone help me what settings should be inserted to config file which will resolve our problem?
