What is the max length of pxSubscript
I want to use PageGroup and want to know what is the max length of pxSubscript ? and how to increase max length if required.
Thanks In Advance.
Thanks In Advance.
Thanks for your response.
I am not creating Declare Index nor i want pxSubscript on column. It will used just as subscript for page group (Data page).
So Can I assume there is no Length Restriction for subscript of page group ?
Mahesh
Hi Mahesh,
pxSubscript property doesn't itself has a max-length restriction.
But I guess if you're creating a Declare-Index for page-group and want this pxSubscript to be a column, then max-length would probably depend on the length of the column. By default column length seems to be 128 characters(atleast for Postgres DB).
-Shruthi
