TDBFG
TDBFG
TDBFG
Posted: Nov 30, 2017
Last activity: Dec 4, 2017
Last activity: 4 Dec 2017 15:47 EST
Max field length in PRPC v5.1
What are the steps to identify standard max field length for text fields in PRPC v5.1 application?
Is there any way the field length can be altered(reduced/increased) in the PRPC system?
Trying to modify the length of a field can be tricky sometimes. Because you can have a validation sort of restriction on the client/PRPC side, but also a hard limit on the DB column size to consider as well.
Depending on the exact behavior you are trying to achieve you might be able to avoid some of these headaches. I would also take a look at this related post.
https://collaborate.pega.com/question/if-we-reset-exposed-property-length-pega-718-version-it-always-considering-old-max-length
