How to modified max length of optimize property
Hi I have a property which is Decimal and once it is optimized , the property become Decimal(18,9) is it possible to update the 9 to 12? And how should i do it ?
@WeiPingT if you have DB access execute the query ALTER table TABLE_NAME ALTER column COLUMN_NAME decimal(9,12) ; you can use RDB methods and perform the same if you dont have DB access.
